Head Gasket Sealant for JD model D
JC
11-17-2003 14:19:34
Several opinions have been expressed on this board WRT using a sealer when installing a new head gasket. The head has been planed. The block has been planed. The studs and nuts have been dressed with tap and die.
What sealer will give years of trouble-free service. I don't care about the cost - for the small amount that I need!
Expert advise would be greatly appreciated.
Thanks,
JC
old
11-17-2003 16:23:28
 Re: Head Gasket Sealant for JD model D in reply to JC, 11-17-2003 14:19:34
I use coppercoat by permatex, the copper moves the heat from head to block a little better then most other sealers, I,ve used it for more then 20 years and haven't blown a head gasket yet.
Will P
11-17-2003 15:22:39
I used Clooneys recommended sealer on my B three years ago after I lost the head gasket.
I milled the head and block flat. Used Permatex #3 and have had no problems in 3 years. And I USE this B. Ran for 3 hours straight on my 22X36 thresher. That was a little bit too much for my 43B with 21HP. It gave all it had. And it just keeps going, and going, and going.
Will P
Clooney
11-17-2003 14:50:33
JC, I'm not sure about "expert" advise, but I have been using #3 Permatex for many years without a single leaker.. I use a thin coat on both sides of the gasket but not on the fire rings that surround the cylinder holes..
~Using a sealer such as Permatex does mandate a hot re-torque though...
~I'm sure some of the modern spray sealers will work just as good but I have had such good luck with the Permatex for so many years that I hate to change something that works..
[email protected]
JC
11-18-2003 04:52:44
 Re: Re: Head Gasket Sealant for JD model D in reply to Clooney , 11-17-2003 14:50:33
To re-torque the head with the engine hot, it looks like I would have to remove the tappet case to get at the head nuts after running the engine for a while .
Am I missing something here? Sounds like a lot of re-work BUT likely the best way to go.
How many hours of operation at full temperature before the re-torque?
Regards,
JC
Henry J
11-18-2003 06:49:12
 Re: Re: Re: Head Gasket Sealant for JD model D in reply to JC, 11-18-2003 04:52:44
JC
Just a passing thought, but do you think Deere did that to all those D's ?
JC
11-18-2003 08:50:25
 Re: Re: Re: Re: Head Gasket Sealant for JD model D in reply to Henry J, 11-18-2003 06:49:12
No, I'm sure that JD didn't re-torque anything. However, responses to an earlier post of mine on this subject suggested using a sealand and re-torquing the head. I've spent so much money restoring this engine i don't want to leave anything to chance, or to this novice wrench swinger.
I'd rather do a little more work now to be sure that it all works well!
Regards,
JC
