Hey Clooney or anyone else
Todd
02-08-2001 15:18:26
In a 51 A Jd transmission, what does the idler gear on the countershaft do? In my tractor it seems to have a lot of play on the shaft. Will this hurt anything?
clooney
02-08-2001 19:03:05
 Re: Hey Clooney or anyone else in reply to Todd, 02-08-2001 15:18:26
Todd, the idler gear is part of the 1st, 2nd & 4th gear reduction system. In 3rd,5th & 6th the sliding gear shaft is driven directly by the sliding shaft drive gear. If you have a lot of play in the idler gear it probably has worn needle bearings and or countershaft. As long as the play is not too excessive or the bearings or shaft is not pitted it should hold up ok. If you are going to pull the tractor or use for extreme duty you should reduce the play in the gear to shaft.
