JD A pulley/clutch assembly
Harvey
02-06-2001 19:11:37
Had oil leak into the pulley, pulled the pulley/clutch, whole works off the tractor. My instruction & parts manual doesn't show me how it goes together and I can't see any oil seal inside. Does anyone have or know where I can get a diagram of how the pulley/clutch assembly goes together on a '37 JD A?
Dave Kolby
02-07-2001 13:44:21
 Re: JD A pulley/clutch assembly in reply to Harvey, 02-06-2001 19:11:37
JD sells the manuals, other sources have them also. Don't know about the older A's but my 1948 A does not have oil seals on the pully side. It relies on the way the shims are installed in the crank main bearing on that side. They must be flush against the block. Also if your crankcase breather is not working crankcase pressure might force oil past the shaft. As for putting it together I never found it to be very difficult. Where are you having a problem exactly?
Dave
