70lp pistons in a 70 gas WILL IT WORK ???
Bob D
02-06-2001 15:49:07
I got a set of nos 70 lp pistons and rings .o45 over and have a 70 gas standard that needs a rebuild. I can bore it out to fit but will these pistons cause trouble or will the higher compression give me more HP ? Any help will be appreciated
Carl
02-16-2001 19:49:00
 Re: 70lp pistons in a 70 gas WILL IT WORK ??? in reply to Bob D, 02-06-2001 15:49:07
HI If you need 70 gas +.045 pistons I have (2)
Chuck McDonald
02-06-2001 20:07:41
Hey,
i read the question and am have some ?'s also. I thought i remember reading in Green Magazine that if you did this, the pistons would get melted or torn up in some way. I would like to hear some input about this.
thanks,
chaz
aka "Tractor Boy"
Mike Aylward
02-06-2001 16:37:50
Bob, the LP pistons will increase your compression ratio to about 7.3:1. They will make a real horse out of your 70. They may be a little extreme for everyday heavy use, but for occasional use they will really wake up your tractor. I run propane pistons in my pulling tractor and get along just fine. You may have to run premium fuel, but I wouldn't hesitate to use them. Hope this helps. Mike
Bob D
02-07-2001 15:24:27
 Re: Re: 70lp pistons in a 70 gas WILL IT WORK ??? in reply to Mike Aylward, 02-06-2001 16:37:50
Thanks for the help. this might be a fun modification to make to the ole 70 !!!
G Taylor Amen Mike
02-06-2001 22:42:47
Right on Mike
