6 volt battery wiring
Kirk
02-06-2001 14:41:19
Bought a JD 40 and JD 420. Neither had a battery so I don't know whether to connect negative terminal to ground or to starter. I assume they are both 6 volt systems because I see no resistor by coil. Which way do the battery cables go? Thank you.
Harvey
02-06-2001 19:07:28
 Re: 6 volt battery wiring in reply to Kirk, 02-06-2001 14:41:19
Kirk, the negative goes to the starter and the positive goes to ground. Just went through this with a 420T. If you buy new cables, don't scrimp on the size. Get the heavy ones.
L.C.
02-06-2001 15:15:28
Both the 40 and 420 were originally 6 volt positive ground systems.
