JD 70D Powertrol Not Working
Nick
02-05-2001 17:19:12
Does the pump need to turned on in order for the rock shaft to travel? When I move the handle to fast down or fast up, the engine slows down a bit and the powertrol box sounds like it is out of fluid. Pump is off; rock shaft does not move.(It's at the correct level)
clooney
02-05-2001 17:43:30
 Re: JD 70D Powertrol Not Working in reply to Nick, 02-05-2001 17:19:12
Nick, it sounds like the pump is turned on to me if the engine slows when the lever is moved to the UP position. Make sure you have the correct plugs in the power-trol outlet ports (NO hose adapters) as the rockshaft won't work without the correct plugs.
