JD Flail Mower
MoosieDog
02-04-2001 21:11:44
I'm not getting any replies to this over in "Implement Alley". So, thought I would check in here with you folks. I bought a used JD 6 1/2 ft. flail mower. It has JD cupped, stamped blades. I see; however, some suppliers offer the "T" type blades for this mower. Seems to me they might cut smoother and with less power loss. It would be an expensive and time consuming change-over so has anyone any experience with the different blade styles?
joe M
02-05-2001 20:03:27
 Re: JD Flail Mower in reply to MoosieDog, 02-04-2001 21:11:44
the straight across single cast blade was the "smooth" cut blade,the hanging pair of "lazy L" blades was for brush and less maintained areas. It stayed sharper longer, but didn't cut smooth as the other.
