How do you get these snap rings unseated!!
Lloyd
02-04-2001 14:21:56
I'm trying to remove the pinion shaft in a 3010 syncrorange transmission. I can't seem to locate a snap ring plier that will grab that style of snap ring. Can anyone point me in the right direction? Thanks in advance.
JD tech
02-05-2001 20:37:10
 Re: How do you get these snap rings unseated!! in reply to Lloyd, 02-04-2001 14:21:56
The snap ring pliers I have used for years for these pinion shaft snap rings are from Snap On. The part # is SRP4. However these are quite expensive. Iam sure that another tool company makes a similar tool, such as K-D for example. The ones I use are about 14" long. If you have a local Snap On dealer or know someone who has a catalogue, you could see what one looks like and find a cheaper one somewhere. Good Luck!!!!!
Fudd
02-04-2001 18:10:46
Are you talking about the snaprings that are tapered on the ends? Any place that sells large truck transmission parts should be able to get the correct pliers.
Lloyd
02-05-2001 06:53:28
 Re: Re: How do you get these snap rings unseated!! in reply to Fudd, 02-04-2001 18:10:46
Yep, those are the ones. Thanks for the help. The people at the local NAPA had never heard of such a thing, and I was wondering if it was a "special JD tool" or something.
