40 T Spark plugs
Daniel T.
11-17-2003 08:39:07
What type spark plug is best?
What do you guys recommend for a 40T I recently upgraded to 12 volt and elecronic ignition?
I need help on this.
Thanks,
Daniel
JDM Guy
11-17-2003 12:25:24
 Re: 40 T Spark plugs in reply to Daniel T., 11-17-2003 08:39:07
I've run Auto Lite 216's in my M (same motor as the 40T)and I've noticed a big difference. It's mostly a work tractor and seems to run good with the 216's.
Clooney
11-17-2003 12:02:01
Daniel, I can't say I would recommend any plug for your tractor.. Try them all & use the one that seems to work best..
~I can say that the Champion H-10C has worked real good in my Dubuque�s that I work, or play hard with.. For light duty use the H-12 or H-14 seems to work well but neither comes is the C [copper] version [at least that I know of].. If I could find an H-12C I believe that would ideal..
~Seeing as you have an electronic ignition there�s a possibility you also have a higher output coil.. If so, you can run about any plug in that 40 without a problem.. The H-10C would probably be ideal..
~On the plug gap?.. I would say stay in the .035� range as that 40 has a rather small distributor cap that is prone to internal arcing.. I doubt you will gain anything by going higher than that anyhow with a stock compression engine.
~One thing you might want to check [or clean] is your distributor ground.. Those Dubuque�s are noted for high resistance between the distributor & the engine block.. If that distributor isn�t grounded correctly you will have all kinds of ignition problem even with an E.I. system..
[email protected]
John T
11-17-2003 10:44:08
Daniel, the plugs specification for that tractor is a function of its reach, location in the combustion chamber, its physical operatign temperature (its heat range) etc., be it H10 or H10C etc. or whatever plug was orignially specified. (Sorry, I have no plug data here) If it called for say the H 10 plug, an H12 would run at a higher temperature which may help burn off fouling deposits somewhat better, if that was a problem you were experiencing.
THAT WILL NOT NECESSARILY CHANGE CUZ YOU HAVE AN ELECTRONIC IGNITION NOW.
HOWEVER, what can change is that with that electronic ignition, and especially if you couple it with a high energy high voltage coil, you can run a WIDER plug gap and get a wider, fatter, hotter, more surface area higher energy spark discharge to better ignite the fuel. Even with the stock coil, due to the faster more positive switching of the solid state switch, you will discharge more energy across the plugs gap with the new ignition. However, a high energy high voltage coil can better utilize the advantages of that switch enabling more energy to be discharged across a wider plug gap for better combustion initiation.
So, just run the plug originally specified, but widen its gap to maybe at least 0.040 or maybe even up to 0.050 or slightly over ?? if you use a high energy high voltage coil, BUT THAT DEPENDS ON THE COIL AND SWITCH SPECIFICATIONS (NOT my best engineering guesses here) plus fuel and compression etc. As you widen the gap and have a high voltage coil, unwanted arcs may happen like at the towers or terminals or leaky plug wires etc., so use good high voltage wires and have good clean dirt, water, and carbon free towers and terminals to avoid arcing other than at the plug gap.
Of course, use a 12 volt coil now (or a 6 volt and external ballast, but I prefer the 12 and better yet, a high energy high voltage unit) and try a wider plug gap (0.040 or more ??? depending on coil and switch) until the HP maxes out.
Good luck n God Bless ya Daniel
John T
Daniel
11-17-2003 11:43:10
 Re: Re: 40 T Spark plugs in reply to John T, 11-17-2003 10:44:08
thanks for the info guys.
I was trying to find a way to convert the plugs to a Platinum tipped plug. That would have a hotter spark and last longer. I was told this would help with fouling plugs. Does anyone have a cross reference for this. Using a Bosch Platinum?
Thanks again,
Daniel
tom
11-17-2003 13:29:42
 Re: Re: Re: 40 T Spark plugs in reply to Daniel, 11-17-2003 11:43:10
Dan,
I know I have seen a post in here b4 with ford, champion and bosch plug recommendations for the M, MT, 40, etc...engine and I thought I saved them, but did not... check the archives and it should be somewhere...
just one thing..have you ever done a compression test on your 40? try that and post back the results...need to know if your burning a lot of oil...
final note, make sure you are using fresh/clean gas, carb is adjust properly and you run your 40 under load every once and awhile...what I was told that these tractors when originally designed and built, they were not for "putting-around"; they were for working real hard...as a result, if we/you do not work them real hard and or ensure clean/new fuel, clean carb. and proper carb. settings, clean air-intake, etc., then you will always get more carbon build-up than you want...if this is wrong, then someone please advise otherwise...
John T
11-17-2003 12:09:33
Sorry Daniel, no plug charts here, still, if you run an electronic ignition with a high energy high voltage coil and a wide plug gap even with the stock plugs, fouling (if was only minor before) shouldnt be too bad a probelem BUT IF IT STILL IS, then you gotta take a serious look at fuel and compression and ring or valve problems. What Im saying is, an electronic ignition is not a cure all (even if a major improvement) if shes fouling extremely bad due to oil consumption or ring or valve or fuel causes.
I still agree with and like all the improvements in igniiton possible, even if overkilled, but if shes fouling baddddd d due to other problems, the electriconic switch and even platinum or superman lol plugs may not cure her.
Good luck, good topic and questions, sorry I cant tell you any the plug numbers.
John T
tom
11-17-2003 10:00:33
Dan,
The Champion H10-C or H10 have been recommended for this type of engine...post what type of work and how often you load her and that will have an impact...
tom
Wayne in Tn.
11-17-2003 11:10:33
 Re: Re: 40 T Spark plugs in reply to tom, 11-17-2003 10:00:33
I have good luck with Autolite 216 in my Dubuques.
