John Deere 410 backhoe loader
Ernest Fancy
02-03-2001 16:02:50
Looking at buying a JD 410 backhoe loader. The owner can not tell me what year it is. Is there a
serial number some place that I can look at and tell the year it was made? How much are these tractors worth? I am new to this market. Looking to used the machine to dig the foundation for my new 26x40 workshop and sell it after I am done.
Is this a good idea?
Jonathan
02-04-2001 06:41:04
 Re: John Deere 410 backhoe loader in reply to Ernest Fancy, 02-03-2001 16:02:50
If I remember correctly ,the serial # tag should be on the right side frame up near the front tire...the last 6 numbers are the important ones for year I.D. ...as far as purchasing for a single use project....that seems to be an appealing idea for many ...until there is a major failure of some sort to the machine....then the initial projects price tag is doubled as opposed to just hiring a contractor to dig the foundation...If you are not familiar with a 410 and arent sure what to check out before purchasing, there is a good possibility you will regret the idea later..e around here --northeast-- is around the 10,000 range...depending on condition ...unless you can get it for "dirt" cheap , and know it will do what you want and can resell it afterwards, wouldnt it be much easier to just make a few phone calls to get prices on hiring the work ???
Ernest Fancy
02-04-2001 10:29:14
 Re: Re: John Deere 410 backhoe loader in reply to Jonathan, 02-04-2001 06:41:04
Jonathan,
Thanks for the feedback. Trying to get a contractor in here last year was impossible. One of them told me to try back in two years. So you are probably right and I probably will regret this, I am going to buy the machine. It is not cheap, It is 12K. Was used at a local camp ground and has not seem much use.
How do I decode the last six digits?
Jeremy Wright
06-25-2001 09:59:32
 Re: Re: Re: John Deere 410 backhoe loader in reply to Ernest Fancy, 02-04-2001 10:29:14
I don't know if you still need the year on your 410 you are going to purchase but if you call a local JD "construction dealer" they should have a book with a serial # to year guide for used equipment. If they can't tell you E-mail me the serial # and I will look it up for you.
