PTO Dimensions
John in OH
02-02-2001 21:04:27
I am refurbishing a 1937 B that has the old size (1-1/8") PTO shaft. The splines on the outboard end of this shaft have been chewed away from years of use. I wish to weld up the splines and remachine them back to the original dimensions. Has anyone out there ever done this? Does anyone know the actual spline dimensions and clearances? Any suggestions regarding the best welding technique and vertical mill tooling to recut the splines? Thanks in advance.
Karl Bader
02-04-2001 16:13:30
 Re: PTO Dimensions in reply to John in OH, 02-02-2001 21:04:27
Take it from me, not a great idea. I did that with a shaft for the hydraulics on a 284 IH. A couple of months later we ended up replacing it anyway because it broke. I suggest you try www.oldjd4u.com Their parts are so far the cheapest I found as well as in the best condition. They really take care of their customers. Tell them Karl sent you!
Hope this helps!
Karl
Shorty Dear
02-03-2001 15:09:30
John, I'll bet you can buy a good used shaft for less money and it would also probably be stronger than a welded one. I think I have a shaft if you want one.
