2020 or 2510
JWS
02-02-2001 18:06:38
Am am considering both and would like some general response on good and bad points. I need a tractor to pull 3-16"s, 10' transport disk, 4-row planter. Which one would be better? And what do good 2020 diesels bring? I saw a 2510 posted for $5,500 I think. Thanks in advance!
john / 2510 and loader
02-03-2001 18:34:47
 Re: 2020 or 2510 in reply to JWS, 02-02-2001 18:06:38
we have a 2510 gas with loader it is the best tractor i have run it will do anything or more then my dads 2020 or 3020 will do on less fuel...is yours synchrorange or powershift?
JD70Jim
02-03-2001 06:44:42
The 2510 is a row crop tractor intended for field work such as tillage, planting and cultivating within it's power capacity. It is fast becoming a desireable collector tractor. The 2020 with the same engine is a utility tractor, ideal for loader work, but with a low profile, making some field work unsuitable for it. Ground clearance will be less, and it has the two stick tranny which is more awkward to use. I also think Dubuque tractors are not nearly the tractor that Waterloo tractors are. Get the 2510. JD70jim
Mike Aylward
02-02-2001 18:25:23
I would prefer the 2510 also. The engines are the same, but I prefer a Waterloo tractor to a Dubuque tractor. Nothing wrong with a 2020, but a 2510 will be a more "deluxe" tractor, and will more than likely even cost less. My humble opinion. Mike
jdeere70
02-02-2001 18:17:58
Just my opinion but the 2510 would be by far a better choice. Again, jusr my opinion. Please refrain from gunfire!
