52JD-MT Electrical ?
Lee
02-01-2001 10:22:06
After removing gas tank, noticed that some of the wiring needed to be replaced. Then found nothing was wired to lower ignition switch, only on/off and amp meter. Also found no cut out relay and what apprears to be a voltage regulator. System works well but doesn't come close to wiring diagram in manual, however; everything works well. Unit has no set up for lights which eventually I would like to replace. System is 6 volt/pos ground. Generator?/Alternator? is definitely after market and rigged in. Does this sound like a common conversion or has someone in the past cut and pasted?
TIA
