JD M Rod Bearings
lbouslog
01-31-2001 17:33:13
My JD M has one rod journal on the crankshaft that is 0.010" undersized....It is pretty smooth and mikes consistently so I believe it may have been turned before. My repair manual says that JD Rod bearings are only available 0.003 and 0.005 under.
1. Where can I get rod bearings 0.010" under?
2. If not...I have to have the rod reconditioned because it spun the bearing...What if I had the rod bored 0.005 under and then fitted it with a 0.005 under bearing? I would probably have to file the end opposite the tab a little so it does not interfere. That should get me to the right clearance.
Would appreciate anyones thoughts on these options.
BobTGS
02-01-2001 12:23:21
 Re: JD M Rod Bearings in reply to lbouslog, 01-31-2001 17:33:13
I, can supply you with bearings , rods, or , anything else you might need. Call Triple G Service ,1-716-542-3175, 9am-8pm. Bob.
Chuck
02-01-2001 05:35:40
don't mess around with the rod, just get another one that's not damaged. Also you can get bearings oversized. As a matter of fact, I think that federal moguel supplies all the bearing anyway. Forgot to say that you better check and see why you had this problem in the first place, you may have a bad oil pump
Chuck
02-01-2001 05:34:43
