3020 hard to shift
dennis from i
01-31-2001 16:21:45
this is a diesel it is very hard to get in reverse somtimes if you pull ahead a little it will go
Gehl
01-31-2001 17:45:03
 Re: 3020 hard to shift in reply to dennis from iowa, 01-31-2001 16:21:45
is it power shift or synchro???? If it is a synchro try spraying some WD40 down the slots by the shifting lever, and moving the lever around.
dennis from iowa
01-31-2001 19:16:18
 Re: Re: 3020 hard to shift in reply to Gehl, 01-31-2001 17:45:03
it is a synchro it is my uncle john
gehl
01-31-2001 19:34:44
 Re: Re: Re: 3020 hard to shift in reply to dennis from iowa, 01-31-2001 19:16:18
I have a 3020 and a 4020, both synchro. I normaly spay mine up 3 to 4 times a year depending on how much snow and rain it has been exposed to. If it is really hard to shift, it may take putting it on 2 or 4 times to work well. Hope it helps.
JDPuller
02-05-2001 19:30:02
 Re: Re: Re: Re: 3020 hard to shift in reply to gehl, 01-31-2001 19:34:44
Sometimes when they don't go into gear, it's not the linkage... there is no cables to spray wd 40 on, only on the powershifts, what happens is on the syncro's is the shifter forks wear adn allow the syncronizers to seperate a hair which causes it to be hard to shift, and eventually it'll just make a grinding noise after a period of time
Brad
