To mag or not to mag
Alan
01-31-2001 13:12:33
Have a 46 model A,cannot get the mag to fire more than a couple of times in a row.Would like to put a dist.on but was wondering how to get the timing right. Thanks for any ideas,Alan.
John T
02-01-2001 05:22:29
 Re: To mag or not to mag in reply to Alan, 01-31-2001 13:12:33
Alan, its really not much harder than timing a mag if you understand when its supposed to fire etc. so here goes. Same as the mag, when the left number one cyl is at TDC on its compression stroke (Left Hand Impulse line on flywheel is at 3 o clock even with mark on tractor side), on a distributor system at that time, the rotor tip will be pointing near the first distributor cap terminal (to left plug) and the points would be approximately at max opening on the high lobe of the cam. The coil fires when the points open, and at that time, the rotor needs to be pointed to the terminal leading to the plug wire its supposed to fire. Then, the fine tune dynamic timing is achieved (same as mag) by rotating CCW to advance and CW to retard. Hope this helps. Ol John T PS A battery operated points/coil ignition in general, supplies more spark energy to the plug than a run of the mill mag, and be sure you wire the coil correct polarity to your tractors set up and use a ballast resistor if necessary with a by pass startign circuit.
