Front weights on 720d
Kevin Arnold
01-24-2001 19:19:03
I purchased a set of front weights for a 720. The weights I have only have 1 bolt hole on the side and one in the very front.They fit the tractor fine, but how does the front weight go on. It looks somewhat like a small "t". The side weights wrap clear to the center of the tractor. The other weights I have seen have 2 bolts on the side,and don't go wrap all the way to the center of the front. any ideas what I need?
luckydog
01-25-2001 07:42:06
 Re: front weights on 720d in reply to Kevin Arnold, 01-24-2001 19:19:03
Kevin-- They made two different kinds of front weights. Sounds like the 2 pieces that goes on the side is one kind of weight that takes no more added pads. The other is the kind that has 2 bolt holes in the side and uses pads. Pads as in the one front weight that you can't figure out how it goes on. Sounds like you have one set of front weights and part of another!! luckydog
