51 g oil filter housing
richard
01-24-2001 16:20:13
getting ready to put holes in rear of case for crankshaft clearence. want to take filter housing out. is it pressed in or does the center stud hold it in. thanks richard
Gman
01-25-2001 16:13:17
 Re: 51 g oil filter housing in reply to richard, 01-24-2001 16:20:13
Richard you don't have to remove oil filter housing to cut windows in case. Just get you one of those little die grinders and some thin disc and go for it. Yhat housing is a press fit and you could open aa can of worms by removing it.I just completed a '51 "G" so been there done it. Clean case out good and before you remove crank turn crank and mark case were to cut,I beleive with some effort I could put mine back in if desided to go back to stock. Then take some thin sheet metal and make pockets to fit in holes I pop rivited mine in used a little silicone for gasket.Hope this helps. Gman
richard
01-25-2001 16:42:00
 Re: Re: 51 g oil filter housing in reply to Gman, 01-25-2001 16:13:17
hey gman. your advise is greatly appreciated. thanks richard
