How do you fill the tire with ballast??
Le
11-16-2003 16:11:27
Just picked up a nice 2040 with loader. The rear tires are in dire need of some ballast. How do you get the fluid in? How much is needed to fill 14.9x28 tires?
Thanks
Le
Jim was in UK
11-17-2003 11:33:05
 Re: How do you fill the tire with ballast?? in reply to Le, 11-16-2003 16:11:27
You can do this at home with an attachment that can be bought at your local TSC, Gebos, and some parts stores. Don't know how much you plan to use this tractor in the winter time, but an alternative would be to use engine anti-freeze. A couple of gallons with the water per tire should be more than enough. Remember to make sure that the valve stem is close to the top when checking the air in your tire. That water will ruin your air gauge as quick as it hits it. Have done this on the tractor tires for a Farmall M and we didn't have any problems. Just another thought you might consider. I am by no means an expert on this subject.
later days mate,
Jim in NM again
Ralph
11-16-2003 20:25:14
Will the common "3-hole" wheel weights fit? C.A. $100 per set used around here. Every time you check the tire pressure you will spill a lttle of that corrosive calcium chloride on the rims. Might be a bit more expensive to begin with, you will pay for removing it and replacing it at $50 per hour. Just replaced tires on two tractors, tire store was a lot more enthusiastic when they found out the tires were not filled with fluid.
SamH
11-16-2003 18:22:20
According to my chart for a 14.9x28, a 75% fill takes 215 lbs of Calcium Chloride and 43 gallons of water for a total weight of 574 #.
As for putting it in the tire, you can do it at home, but it ain't worth the trouble to me because my local farm store will do it for a reasonable price.
