Cat. 1 or 2 or 3 hitch on a J.D. 2520
Dan
01-20-2001 14:34:28
I am the new owner of a J.D. 2520 gas tractor, and would like to know if the 2520 has a cat. 1 or a cat 2 three point hitch. I have a dearborn two bottom plow which I hope I can use with this tractor. The plow I have is a 3--point hookup which came with a Ford 8N tractor, which I no longer have. Any advice I receive on this will be a great help----Thanks
Mike Aylward
01-20-2001 17:10:53
 Re: Cat. 1 or 2 or 3 hitch on a J.D. 2520 in reply to Dan, 01-20-2001 14:34:28
Dan, the first thing most of us would advise would be for you to get an Operator's Manual for your tractor. They are available directly from John Deere at 800-522-7448. This is the first thing any tractor owner should get for his tractor if he didn't get one with it. In the manual you will see that your 2520 is a Category 2 hitch that is convertible to Category 1. You will have to install your sway blocks to the narrow Cat. 1 setting, then use bushings in the hitch pins to bush up to Cat. 2. You may even need to remove the sway blocks for plowing, although I prefer not to. It's a pretty simple job to convert. Hope this helps. Mike
