RPM of Generator
John D
11-16-2003 14:54:45
Could some one tell me what RPM a generator runs at fast or slow idle on a Styled G. Thanks John
Clooney
11-16-2003 15:24:42
 Re: RPM of Generator in reply to John D, 11-16-2003 14:54:45
John, I don't think you will find that info in a reference manual..
~You can figure it yourself though..
~If you have the 12 volt 1101755 generator it's rated output RPM is 2200, that will probably work out to be around the rated engine RPM of 975 RPM, so that would put the generator RPM at around 1350 at 600 idle RPM.. That's assuming the generator is run at rated output at working RPM..[just a guess though]
~OR to be more precise,, you can put a paint mark on one of the generator's cooling fins the also mark the flywheel, then turn the flywheel one full revolution, then count the generator fan revolutions [it will be more than one revolution & probably more than two].. Then it's a simple matter to figure the drive ratio...
[email protected]
John D
11-17-2003 09:23:25
 Re: Re: RPM of Generator in reply to Clooney , 11-16-2003 15:24:42
Clooney, what a good idea. Thanks John
