Model B head will not slide! Now What?
Bill Oakes
01-18-2001 18:13:49
Finally working on the engine of my '48 B. Terrible compression in one cylinder. Valves move when I turn engine by hand. I am guessing that a valve is badly burnt. I am trying to remove cylinder head. My manual says to remove hex nuts from studs and then "slide the head forward". I must have missed something cause I can't get it to move. How big a hammer can I use without breaking something. I am hoping some of you more experienced John Deere men can offer advise on getting this off. Please!! Thank you for any advice you can offer.
Bill says Thanks
01-19-2001 06:01:42
 Re: Model B head will not slide! Now What? in reply to Bill Oakes, 01-18-2001 18:13:49
You guys are a great help and encouragement. With all the tips you've offered I am going back at it tonight after work and just sure I can get that rascal off. Thanks again! Bill
BMAN
01-18-2001 21:57:16
I put a 4 X 4 block of wood behind the manifold and hit the wood with a large hammer. Its never failed yet.
Chuck
01-18-2001 20:01:27
with all the head bolts off there is nothing to hold the head...I always use a screw driver between head and block. There is a center head bolt with cap that feeds the oiler for rocker arms...be sure to remove those items.....
tractorboy
01-18-2001 19:23:31
Have you got the oil line loose from the rear fitting ?
Duke
01-18-2001 18:39:15
lead washers are used around the studs to seal them. Use a scraper to clean them off, make sure you have all of the nuts off, then pry it off. You should not have to pry with any thing longer than 12". A hard pry can break a head. good luck.
Larry E
01-18-2001 19:21:07
 Re: Re: Model B head will not slide! Now What? in reply to Duke, 01-18-2001 18:39:15
I recently removed head took all nuts off bolts and pried head off .I failed to take oil line loose that goes to rocker arms and broke it,it is hard to get to but must be removed.John Deere dealer wanted $26 for new line .Igot one from junk tard for $1.
