JD 70 intake manifold
Flatback
01-16-2001 19:14:36
Have JD70 gas. Would installing LP manifold help performance?
al
01-18-2001 18:57:05
 Re: JD 70 intake manifold in reply to Flatback, 01-16-2001 19:14:36
If you are looking for power,I have heard cutting out the divider plate inside increases increases power dramatically.It lets each cylinder use the 2 barrel carb.
STMTS
01-18-2001 18:04:08
If your going to pull it the answer is yes ,it seperates the exhaust heat from the intake air which allows cooler and more dense intake air,as was stated earlier, if your just going to put around it would not ever seem to warmup.
G Taylor
01-17-2001 07:25:38
LP manifold if used for pulling or steady moderate to heavy field work . For just putting around in the fall,winter & spring or for parade duty the gas manifold with the heat applied is better.
