Fan Bearing on JD H
phil
01-15-2001 11:45:11
My 1940 JD H has a grease cup mounted above the front fan shaft bearing. The cup unscrews about half way, then hits the exhaust pipe. Do u have to remove the exhaust pipe to fill the grease cup or is there an easier way? The Owners Manual doesn't mention this cup - what to do - fill with wheel bearing grease, give it a half turn every year, anyone know? Thx
Donny-B
01-15-2001 14:14:03
 Re: Fan Bearing on JD H in reply to phil, 01-15-2001 11:45:11
Phil, I have a 41 H that has a 90 degree grease zerk on the fan bearing. The 46 parts tractor I have also has the zerk. I think someone had installed the cup for ease of greasing but had the pipe removed and did'nt realize the problem until it was too late!
phil
01-15-2001 15:03:16
 Re: Re: Fan Bearing on JD H in reply to Donny-B, 01-15-2001 14:14:03
Donny-B
Thx, the 90 degree zerk makes a lot more sense, maybe I'll put one in.
jimbob
01-21-2001 18:08:28
 Re: Re: Re: Fan Bearing on JD H in reply to phil, 01-15-2001 15:03:16
My 1939 "H" also has the zerk.
