A question for Clooney
Wayne Johnson
11-16-2003 08:28:38
I was told you could bore an early styled B 1944 .200 over and install either late styled b or model 50 pistons and rings. That sounds like a lot to me. Can it be done and what would be the advantage/ disadvantage in piston choice? It's a hand start.
Mike M
11-17-2003 07:18:09
 Re: A question for Clooney in reply to Wayne Johnson, 11-16-2003 08:28:38
This seems like a lot to me too! But I have heard
stories from a few old timers that it has been done and worked fine on the farm. You could run into a sand hole or thin cyl. from rust. I was lucky enough to find some NOS .045 over gas pistons made for these tractors at Stephens Equipment a few years back when I did mine.
Clooney
11-16-2003 09:17:27
Wayne I'm not a puller so haven't tried what you are asking..
~Look in the archives & find the E-Mail address of WTW, he has probably tried just about any combination of "B" piston/bore combinations that could be thought of...
Wayne Johnson
11-16-2003 15:47:34
 Re: Re: A question for Clooney in reply to Clooney , 11-16-2003 09:17:27
Just where would I find the "archives"?
Clooney
11-16-2003 16:00:17
 Re: Re: Re: A question for Clooney in reply to Wayne Johnson, 11-16-2003 15:47:34
Wayne, click on the link, then near the top center of the page you will find a box that says search for.. Put WTW in that box & click go..
~In case you can't make it work WTW's E-Mail address is [email protected]
