CARB ON 3020 GAS
JOHN
01-14-2001 19:01:09
ON MY 64 3020 GAS THE NEEDLE AND SEAT HAS BEEN STICKING SOMETIMES DRIPING GAS FROM THE CARB. I TOOK THE CARB APART AND NO DIRT INSIDE EVERTHING LOOKS REAL CLEAN NO GUM OR VARNISH. I TRIED TO GET A CARB KIT FOR IT BUT ITS NOT LISTED IN STANDARD HYGRADE AT PARTS STORES ITS A ZENITH CARB. CAN I JUST GET A NEW NEEDLE@SEAT FOR IT?? IS THIS COMMON FOR THIS CARB STYLE??
JOHN
01-15-2001 11:06:44
 Re: CARB ON 3020 GAS in reply to JOHN, 01-14-2001 19:01:09
DOES ANYONE KNOW HOW MANY TURNS THE JETS ARE ON THIS CARB AND SHOULD THE FLOAT BE SET LEVEL WHEN UPSIDE DOWN?? THANKS
Darryl
01-15-2001 09:18:32
I had the same thing happen to my 3010 with a Zenith Carb. Took it apart, found nothing wrong, put it back together and it's been running ever since. You may want to try that.
JOHN
01-15-2001 11:02:16
 Re: Re: CARB ON 3020 GAS in reply to Darryl, 01-15-2001 09:18:32
AFTER SOAKING THE CARB IN CARB CLEANER FOR 24 HRS I FOUND A SMALL HAIR LINE CRACK IN THE FLOAT BOWL THAT EXTENDS DOWN 3/8 OF A INCH. LOOKS LIKE THE PREVIOUS OWNER WAS TAPPING ON IT TO GET THE FLOAT TO STOP STICKING LOTS OF MARKS ON THE SIDE. I AM THINKING ABOUT JB WELDING THE CRACK. ANYONE GOT A BETTER IDEA. DOES ANY ONE HAVE A BOTTOM HALF FOR A ZENITH CARB THEY WOULD GET RID OF??
