Engine starts sputtering when pulling steep grade
Charles
11-16-2003 06:44:33
My 1952 JD B has just started sputtering when you go up a fairly long steep grade. It's OK otherwise and the engine is OK until I get near the top of the grade. I am getting gas OK to the carburetor. One thing I do know that is not right is the idle needle needs to be turned out almost 4 turns for the engine to idle smooth. The load needle seems good at about 1 turn. The throttle shaft may be a little loose (which I understand can allow air in and cause improper gas mixure).
All you guys are great as you just helped me solve my charging problem (It was the voltage regulator)...Thanks Very Much.
Thanks again Charles
Clooney (Fuel Problem)
11-16-2003 09:14:00
 Re: Engine starts sputtering when pulling steep gr in reply to Charles, 11-16-2003 06:44:33
Charles, that... " sputtering when you go up a fairly long steep grade. It's OK otherwise and the engine is OK until I get near the top of the grade" ..Is usually caused by the carb running out of fuel after a long hard pull.. I'm guessing you will see the same thing if you hooked it to a disk or plow..
~It sounds like you might have two different problems.. The first is that there is a blockage in your fuel system or tank vent.. The second is an internal blockage in the carb's idle circuit [common on those old DLTX carbs], or a vacuum leak?
~Let's address the fuel system blockage first.. Open the carb's drain cock on the bottom of the carb & MAKE SURE you have a pencil sized stream of fuel flowing for at least 30 seconds [or in your case as long as it takes to climb that hill].. My guess is your fuel flow will slow to trickle after a short while.. If that's the case try the test again with the fuel cap removed.. At least you will then know if you have a tank vent problem [OR, just go climb that hill with the gas cap loose].. If the tank vent isn't the problem then loosen the fuel line at the carb & try the test again.. One place to look is if you have a 3-way valve that it is turned to the CORRECT position [that 3-way has caused more than a few tractors to act like yours].. In any case work your way through the fuel system & see if you can find the problem.. Remember there is also a strainer in the carb at the well where the fuel line enters..
~If your fuel system passes the fuel flow test then the next place I would look is the main nozzle [that could have a few plugged air bleed holes on it's side & could cause a long pull metering problem]...To access that, just CAREFULLY pull the float bowl's lower nut & float bowl, then [don't lose the spring under the nozzle], then find a tap that will fit the lower end of that brass nozzle [it's up in the main well just above where that nut was],, then run that tap into the bottom of that nozzle about 3/8" [NO drilling necessary],, then install a piece of all thread [or a long bolt] with a stack of washers & a nut,, when that nut is tightened it should pull that nozzle out [CAUTION: don't pry on the top of that nozzle as those nozzle tops are easily damaged.... Once the nozzle is out, clean the little side holes with a small wire or torch tip cleaner..
~Another place to look is into the fuel tank.. On those old tanks the fuel fill baffle is known for falling down around the tank outlet & causing a fuel flow problem when the fuel level drops to below that fallen baffle height [like when climbing a hill]..
~It might not hurt to look at the air cleaner cup for water or other junk.. Doubtful but possible you are pulling something into the intake under full sustained load..
~If you can't find anything with the above post back or E-Mail for other things to look at..
~On your idle problem..That sounds more like a plugged idle passage or maybe a vacuum leak.. If you have severely worn throttle shaft bushings that could be your idle problem. Another place to look is for a real loose idle needle in it's carb threads... Try some heavy oil around the throttle shaft bushings to see if the idle richens up a little [spraying some combustible around the throttle shaft will more than likely show an idle improvement even with decent shaft bushings as those bushings aren't sealed]... If the idle needle is loose try some pipe sealer on the threads... If the above doesn't point to something you probably have a blockage in the carb or severely worn intake valve guides.. Another thing to look at is the end of the idle needle, if it's bent, worn with a ring in it, or otherwise distorted that could cause your idle problem...
~If nothing obvious is found on the idle problem & the tractor idles ok at 4 turns out maybe you have a partial plugging of the carbs idle circuit.. You might try some carb cleaner down the idle needles screw hole to see if maybe it's just a gum problem... If you still have idle control even at 4 turns out you can probably live with it there. If it's out 4 turns but you lost idle mixture control at 3 turns out then you have a carb problem.. Try pulling the choke out & seeing if that helps the idle, if so you will probably need to remove the carb & clean the idle passages out..
~I doubt you have an ignition problem as it doesn't seem to be time, temperature, or a short time load problem... Those long hill climbs really bring out the worst in a fuel starvation problem so that would probably be the place to start..
If you decide to go into that carb & clean the internal passages just give me an E-Mail & I will send you a carb breakdown showing the passages that need attention..
~Let us know what you find when you get it to climb that hill without losing power?
[email protected]
Charles
11-16-2003 11:27:32
 Re: Re: Engine starts sputtering when pulling stee in reply to Clooney (Fuel Problem), 11-16-2003 09:14:00
Thanks Clooney,
Your responses have been of the greatest help. I will try everything you suggested.
Again I am very grateful...Charles
John T (Troubleshooting)
11-16-2003 07:53:32
Good Morning Charles, Congratulations on gettign the charging system going. As far as your cutting out when going up a "fairly long steep grade" Im going to suggest a few possible causes FIRST related to the tractor being faced uphill and SECOND to general causes of insufficient fuel in general. WHEN THIS HAPPENS DOES SOME CHOKING HELP????? ??? IS IT UPHILL ONLY????
*****CUT OUT CAUSED BY ELEVATION OF TRACTOR*****
If the cut out seems caused by the tractor being uphill long periods BUT she pulls fine under a heavy load on level ground, take a look at these things:
1) Is there anythign loose in the gas tank which can fall down into or near the outlet in the uphill or any position???? If there is and it only starves for fuel in the uphill position, find and repair/remove it inside the tank.
2) To be safe, you may want to remove the sediment bowl, have the gas on, and make sure a good gas flow out the lil top holes takes place EVEN IF THE TRACTOR IS IN THE UPHILL POSITION. Dirt or rust or crud can collect in the tanks outlet or sediment bowl assembly inlet pipe or the lil mesh screen if it has one. If worse comes to worse (there is a restriction), you may have to remove the sediment bowl assembly and clean its inlet and the tanks outlet etc BUT BE VERY CAREFUL tryign to remove cuz you can bust the fragile seal into the tank AND NO NOT DO THAT UNLESS ITS ABSOLUTELY NECESARY, ie theres a flow restriction and you cant clean it by air or wire etc. When you check the gas flow, do it tractor parked uphill, and if shes fine there or level, that likely NOT any problem so you dont have to worry about this paragraph or riskign removal.
3) The float level settign in the carb could be set too low or marginal.
4) Make sure theres no water in the gas tank, sediment bowl or air cleaner bowl, cuz as its heavier than gas, it can get into different places depending upon the tractors elevation.
***********CUTS OUT UNDER LOAD EVEN IN LEVEL*****
1) If she cuts out under load even if level, try openign the load needle a tad more and see if a slight amount of choke helps things??
2) BE SURE THERES GOOD FLOW INTO THE CARBS BOWL by openign the lower drain cock/plug and with gas on see if a continuous stream 1/16 inch or so flows out.
3) Be sure the air cleaner is clean and water free and has no restrictions.
4) If choking helps some if she cuts out under load, the main center vertical brass nozzle may have some restrictions. If so, you usually have to run a tap in its center bore, use a bolt and nuts n washers to extract it, DO NOT PRY ON ITS TOP YOU MAY BEND OR CRUSH IT, and once out clean and wire brush all of it and its bore and ALL ITS LIL SIDE HOLES and replace that lower spring in the bowl.
5) Of course, if you get into the carb, go ahead and clean out ALL PASSAGES, post back if you go into it for further instructions.
*******************IGNITION*******************
To be safe, look at BOTH spark plugs and insure they produce a good visible BlUE and NOT a faint thin wimpy yellow spark, and post abck if they do for igniiton teourleshootign tips. If they appear fouled or blackened or carboned up FIRST TRY A FRESH SET OF PLUGS, maybe Autolite 388. Similar, if the points are burned or pitted or carboned or have a heavy gray oxide coating, replace and gap them and try her.
***************VACUUM LEAKS*******************
You mentioned your throttle shaft bushings are worn and YES that can cause an air leak which leans the air/fuel mixture and can cause cutting out or needing choke or havign to run the carb richer. HOWEVER, the maximum vacuum occurs with the throtle plate more closed, and thats at idle more so than open throttle. YOu mentioned havign to run the idle neelde rich, if theres bad vacuum leaks, it may well indeed be past the worn bushings. At idle spary wd 40 or carb cleaner or an unlit propane torch around the carb and gasket and throttle bushings and if it makes her speed up or smooth out, you have found the vacuum leak which needs fixed to improve idle and the carbs settigns.
If the idle needle is way out, THATS ALSO a source where air may be sucked in!!!!! !!!!! Look to see if shes leaking there by the method above and maybe teflon sealer could help, but you really need to fix the problem (maybe worn bushings or clogged interior passages) causing that in the first place, cuz 2 turns out ought to be about right NOT 4. The vacuum test above needs to be utilized, and if theres no leaks, then suspect a clogged interior idle passage, if so, post back.
Plugged interior idle passages can cause havign to choke or mis adjust the carb, so if youre going into it, again, post back for more help.
There are plenty more possibilities but this should be a start. Hopefully, others can add more to this list and offer other opinions on things to look for and we can all learn from you good question.
Post back or e mail [email protected] findings and any more questions.
Good luck n God Bless ya Charles,
John T
Wayne in Tn.
11-16-2003 07:34:01
Charles, I would try opening up the load needle another half turn or so.
