70 D Starter
Moye
01-13-2001 15:43:33
I recently purchased a JD 70 D that runs good, but somewhere in its checkered past someone pulled the pony and tried to use a Delco-Remy electric starer from a diesel truck. They tried to use the ES to drive the pony transmission and broke the transmission. My question, has anyone made this conversion, and how did you do it. I still have the Starter and can make brackets, but any help will be welcome. If you think your post will be too long, email me. Thanks, Moye
MIKE HANLEY
01-18-2001 03:04:11
 Re: 70 D Starter in reply to Moye, 01-13-2001 15:43:33
I HAVE TWO JD 730D THAT I CONVERTED TO 12 VOLT.YES I SAID 12 VOLT. IT IS TO LONG TO GO IN TO HERE. IT COST ME UNDER $300. PRICE MAY BE MORE NOW AS IT WAS SEVERAL YEARS AGO I DID IT. I CAN SHOW HOW TO REWIRE IT AND YOU MUST GET THE LATE STYLE 730/830 STARTER TRY USED PARTS DEALERS. I KNOW A FACTORY REBUILT PLACE IN ADAMS WISCONSIN THAT THEN CAN REBUILT IT. A 70 OR EARLY 730 STARTER WILL NOT WORK. CALL ME AT 608 654 5417.
Moye
01-14-2001 17:17:13
Thanks a lot to both of you. Another person gave me the name of Clyde Wilson of Wakeman OH. I think I will give him a call in the morning. I really appriciate the help as I would like to get this thing where it will crank on it's own. My daughter is not always around to pull me, and my wife won't. :) Moye
Bill E.
01-14-2001 02:27:39
I think there's a supplier from OH that makes the brackets to convert the pony to electric using big 12v starters. Not sure the price. I saw a 70 converted and one thing I remembered was that the crankcase needs to be vented because the pony took care of it. If not, the tractor will run and spit oily soot and make a mess! The tractor also got a gas hood and looked pretty sharp. Good luck.
Bill
JDGnut
01-15-2001 17:15:12
 Re: Re: 70 D Starter in reply to Bill E., 01-14-2001 02:27:39
Bill.. do you know if it was a gas hood.. or a 720 ele start hood.. the Filler neck is in a different location on the Gas 70's.. The sheet metal is the same on the 720 as the 70.. just painted different.. Later.
JDGnut
JDGnut
01-13-2001 23:57:33
If you can find the Electric start bracket for the later 720's and 730's.. they will both right on.. but You will have to find a starter.. I built a bracket for mine.. and used a starter for a tractor like a 4440 or something of that size.. it works good and starts everytime.. good Luck
JDGnut
