720 FAST FURIOUS
NIGEL B
01-13-2001 10:01:45
MY FRIEND HAS JUST TOOK DELIVERY OF HIS 720 BUT HE ONLY HAS GEARS 5&6, WHAT IS THE BEST PLAN OF ATTACK? REGARDS NIGEL B
Gman
01-13-2001 16:47:46
 Re: 720 FAST FURIOUS in reply to NIGEL B, 01-13-2001 10:01:45
Nigel pull the top of transmission the shifter rails might be out of position or shifter fork bent.My "41 "G" had a a broken shifter slot,thats were the shift lever goes in to move the fork along the shift rail,this could be your friends problem. Just an idea Garland
Chuck
01-13-2001 16:18:40
sounds like a tear down, most of the gears needed in transmission should run around $1000 if rebuild. Recommend taking the shifter off first and go as deep as necessary.
