430s John Deere power steering pump
George
11-16-2003 00:14:27
In need of a power steering pump for 430s JD.Cannot find one,can anyone help me? Thanks George
Clooney
11-16-2003 04:29:27
 Re: 430s John Deere power steering pump in reply to George, 11-16-2003 00:14:27
George, those pumps are getting real hard to find..
~If you can't find one you can always build a custom mounting bracket & install a mid 80's GM power steering pump.. If you don't modify the tractor you can then always install the correct pump at a later time when you find one..
Henry J
11-16-2003 06:10:47
 Re: Re: 430s John Deere power steering pump in reply to Clooney , 11-16-2003 04:29:27
George
I have always heard the same remedy as clooney talked about. I would also try a NAPA store and take the old pump in with me. There was an article in Green Magazine a long time ago about those pumps and that was the recommended remedy. If the parts counter cares the can possibly find a pump that will fit in your case, but that is just a thought. Or if you have an old time junk yard like by me go when the snakes are sleeping, take the JD pump along, and parouse the ole GM iron. What the hey, a correct policeman will have to stand on his head and use a flashlight to see it.
By the way if you find one that pops in there please let us know. Good LUck
George
11-16-2003 22:18:44
 Re: Re: Re: 430s John Deere power steering pump in reply to Henry J, 11-16-2003 06:10:47
I want to thank both Clooney and Henry J for your info.I will let you two know what i do and what i find out.I`m helping a good friend in need with this problem.I have a small mower and garden tractor shop. I run into this type thing often.So if in the future i can help let me know.And thanks again for the help. George
