720 D STD. question about foot step
Tracy Redd
11-15-2003 21:28:46
I bought me a angle steel for the foot step in front of flywheel cover. I am trying figure out how angle steel bolted on left rear axle. Does it bolted under the fender mount bracket or above the bracket? It has 4 bolt, which side angle steel bolted on the wheel side (2 holes) or transmission side (2 Holes)? If I put it under the fender, the fender will not be level. There is 3 holes that at the bottom of fender in front of brake drum. Is that it?
Thanks
Tracy
Mr. Green
11-16-2003 07:34:59
 Re: 720 D STD. question about foot step in reply to Tracy Redd, 11-15-2003 21:28:46
It does not bolt onto the axle or where the fender bolts onto the axle. The fender has 3 holes on the side at the bottom for the step support.
