JD G gov wieghts
Mike
01-10-2001 13:16:35
Replacing broken coupler on oil pump today, found pin dropped out of gov wieght and wieght got jammed in cam. There is no easy way to replace that wieght as far as I can see, any suggestions? Mike
Roy
01-10-2001 17:58:01
 Re: JD G gov wieghts in reply to Mike, 01-10-2001 13:16:35
Remove the 4 bolt cap on left hand side of gov.,remove the set screw and control lever on top of gov.,pull the gear and shaft assembly out where you took off the cap, repair it as needed, be sure to adjust bevel gear clearance when reassembling, your service manual will show you how to do this, have fun!!!!!
Gman
01-10-2001 19:41:35
 Re: Re: JD G gov wieghts in reply to Roy, 01-10-2001 17:58:01
Roy the other post covered about everything but I would like to add just a bit. If you haven't disassembled it as of yet,remove starter and crankcase cover and align markes on crank and cam gear,so when you pull that four bolt cover of the marks on cam gear and governor should be aligned up at six o'clock on govenor gear.also you might want to loosen govonor housing bolts don't remove them just back them off where you can raise the housing just a tad,by all means install new weights and pens they're expensive. Wheen you go to reassemble the little arm on the govenor weight goes between gear and govonor slide,now you will think it goes in that slot on the slide assemly,take my word for it doesn't go there been there and done and done it it isn't no fun taking that sucker back apart and putting the arm behind the slide assembly. good luck Gman
BOB VAHEY
01-11-2001 16:00:39
 Re: Re: Re: JD G gov wieghts in reply to Gman, 01-10-2001 19:41:35
Mike Aylward
01-11-2001 07:10:13
Mike, I would agree with all that has been said here except you don't want to line up the timing marks on the governor gear and the cam. With the main timing marks on the flywheel and case lined up (slots in flywheel will be horizontal) just make sure then when you set put the governor together that the mag/distributor drive slot is also horizontal, which will make the timing mark on the governor gear either straight up or straight down. The simple way is to turn the tractor over until the mag slot is in an easily referenced spot, do your repair to the governor, then just put it back like it was. Hope this helps. Mike
Gman
01-10-2001 19:40:42
