2510 Seat
Steve
01-10-2001 10:19:03
On my 2510, when I sit in the seat it bottoms out. I looked under the seat and noticed that in front is a sort of wheel with a small cable running over it. The cable does not seemed to be connected on one end. What is this for and is this my problem? If this is not my problem, do I need a new shock and spring or what.
WTW
01-10-2001 10:37:21
 Re: 2510 Seat in reply to Steve, 01-10-2001 10:19:03
Steve, The cable that you are looking at is to help pull the weight of the seat back when you diced to move it forward or back. The suspension is a spring that is around the shock. The shock is for shock purpose only not suspension. To increase the spring load/ tension there is a bolt head that sticks forward right in the same area of the seat latch lever, you would normally just turn it one way to increase tension and the other way to decrease seat load tension, but if it is like most it will be stuck and need to be loosened up. Take it apart and rework it , it all can be fixed. Good Luck Dave Wickman
