Help with my JD 2010
Scott
01-09-2001 12:28:03
I have a 1963 JD 2010. It has worked like a charm until I screwed things up. I did not know that it had positive ground and I fried the wiring trying to jump it. I have replaced the wiring harness and the voltage regulator and she still will not even try to start from the key. It will however start when I jump it from the solenoid to starter. It will run great with no problems. Looks as if I need to replace the ignition switch???? If someone could plz verify that with me. Also, is there a way to jump the wires from the wiring harness at the ignition switch to see if it will start. I have tryed with no success. Help!! Need my tractor back!
Sam
01-10-2001 18:47:32
 Re: Help with my JD 2010 in reply to Scott, 01-09-2001 12:28:03
Check the fuses-most Dubuque tractors had a fuse on the dash. If it is blown the ignition switch will not work.
JR
01-09-2001 16:23:28
Sounds like you might need a ignition coil. I was charging the battery on my Power King Economy tractor(tractorbarn.com under"Greggs PK site" if you want". Anyhow it has a 3-position key and has a push-button starter. The 3 pos. key is OFF,ON-1,ON-2 the ON-1 doesn't do anything but keep the power on. I left it on ON-1 and the next morning there was a big splatter of oil and the wiring harness was burnt. I blew up the ignition coil. That oil in there is known to be cancerous,so I was careful wiping it up. Put another coil and wiring and it was fine. This probaly wasn't much help so Good Luck.
Tom in Mo.
01-09-2001 16:14:47
Hello Scott, The JD service manual SM-2035 has complete wiring diagrams for all variations of 2010's. Sounds like the switch but could be the connection at the solenoid. Sometimes the marginal connections open when stressed.
Scott
01-10-2001 07:41:14
 Re: Re: Help with my JD 2010 in reply to Tom in Mo., 01-09-2001 16:14:47
Thanks, will look for a wiring diagram. Just looked
at the manuals on this site and they want $130.00
for the SM-2035 manual.
JOE
01-11-2001 07:55:33
 Re: Re: Re: Help with my JD 2010 in reply to Scott, 01-10-2001 07:41:14
scott, I have the manuals. Please e-mail me (directly) your u.s. mailing address and i'll send you a copy of wiring diagrams. Joe
Tom in Mo.
01-10-2001 20:28:19
Scott, The John Deere dealer only wants $70 for an original new one! Check out the dealer!
