Considering purchase of '67 1020 gas
Brian in S. IL
01-08-2001 23:30:59
I stopped and looked at a '67 1020 gas today, the tractor has been repainted and from 10 feet away, looks like a brand new tractor. Get a little closer, and things don't look so rosy, the steering wheel is weathercracked and looks like the tractor spent it's entire life sitting outside. The tach reads about 230 hours, but I looked in the battery compartment and noticed that the tach cable is gone. Looked at the radiator, it looks like a previous water pump let go and the fan went into the radiator. But overall, the tractor doesn't look abused, just the things I stated were the major items I could see. I'm really just wondering if there were any problem items with the 1020's in general. What should I look for? The guy is asking $5000, which is what the black price guide book says is normal for a 67 1020 in good condition. Thanks a bunch,
Brian
Ken McWilliams
01-09-2001 18:46:33
 Re: considering purchase of '67 1020 gas in reply to Brian in S. IL, 01-08-2001 23:30:59
Brian,
The 1020 (301 industrial) is an excellent tractor. I have a 1972 gas. It would take a lot for me to part with it.
Look at it with a critical eye. Start it and listen to it run. Listen for knocks and ticks. Watch the oil pressure and see how fast it rises. If in good shape should almost jump to 50 PSI when starting.
Check the 2 stage clutch and make sure both are working OK. Make sure you can start and stop the PTO with the clutch while the transmission is in gear. Give it gas and try to slip the clutch in 8th gear. If it kills the engine or has to be feathered to get it to move, then the clutch is good.
Go through all 8 gears and listen for excessive noise. Accelerate and decelerate and listen for excessive backlash.
Stop several times and change gears at a dead stop. The transmission is a collar shift arrangement and if the lever doesn't want to easily go into gears then the gear tips are worn from engaging while still moving unless it has a shuttle shift.
Try each brake and then together. The brakes are hydraulic and are almost like power brakes.
Turn the steering wheel from lock to lock. It should stay easy to turn throughout the steering wheel movement. The hydrostatic steering is almost effortless to turn.
Put an implement (preferably a bush hog) on the 3 point hitch and raise it also try to use the PTO. After trying it out, raise the implement and turn off the engine to see how fast the hitch will leak down. If more than 5 minutes, it's in good shape. (Mine has leaked down in about 1 minute for the last 7 years - just too lazy to fix it.)
Don't be concerned about it being gas. It's a robust engine and the 3 cylinder is extremely torquy. It's hard to kill when loading it.
Ken McWilliams
Dayton, OH
JR
01-09-2001 10:59:41
Be careful, I don't like the sound of the tach being disconected. Some dishonest people paint junk tractors just to get them to sell quick. If there is lots of overspray and paint on the gauges for example and paint where is shouldn't be than it's a dead giveaway that the guy is trying to sell junk. If the owner treated it like that then eventually other problems will arise. A neighbor's 2020 Diesel is a great tractor,the tach stopped working on it. Handy with the JD loader. I bet the 1020 is just as good but smaller. I don't like the two shifters though takes a little getting used to the gearshift pattern. Hard to get my size 13 boots past the shifters too.
