Cam Bearings for LA
Bear
01-08-2001 15:58:28
I am rebuilding my LA Deere engine and need to replace the cam bearings (along with all the others). Deere Co only offers the rear bearing. My question: is the front bearing the same size as the rear? Parts catalogue shows two seperate numbers. Will a rear bearing work in the front?
Thankx!!
AWB
01-09-2001 06:23:11
 Re: Cam Bearings for LA in reply to Bear, 01-08-2001 15:58:28
I too am rebuilding a John Deere LA from the ground up piece by piece, and ran into the exact problem you are faced with. Any competent machinist can fit your camshaft with a front bushing..That is what I did and it worked fine.
