Pressed steel wheels on a 70
BigJ
01-08-2001 14:33:12
I have the cast centers on my 70 and was wondering how much weight could be lost by finding a couple of those 3.1/8 wheel hubs and putting on pressed steel wheels?Has anyone tried weighing the two to see the weight difference?I will be using the same tires.Thanks,Jack(TN).
papafoutz
01-14-2001 13:35:51
 Re: Pressed steel wheels on a 70 in reply to BigJ, 01-08-2001 14:33:12
BigJ The cast hubs on my 70 weight 281#,the rims were 87#.The press rims that I put on was 14x38 and they weight 159# and the hubs were 66#. This might give you an idea what they weight.papa
luckydog
01-09-2001 05:52:17
Mike-- Bigj was pretty much correct. You can use M/W hubs off of a 3010 or a 4010 I think. luckydog
Mike
01-09-2001 07:03:47
 Re: Re: Pressed steel wheels on a 70 in reply to luckydog, 01-09-2001 05:52:17
I have a set of 3010 hubs I want to adapt to one of my G's, the axle size is correct, I think I can make a specail key to lock the hhub to the splined axle but havenn't attempted it yet
mike
01-09-2001 03:51:07
On my G I think I lost over 400#s. Careful w/ the hubs, diificult to move, easy to crack. I made adapter plates to run 99 bolts on 6 bolt hubs
