Head repair
Earl
01-06-2001 17:03:49
What are the tudes called that run thru the head on a 2 cylinder,the push rods run thru them and they pass thru the water passage,they are the length of the head,how do you remove them and where do you find new ones. 1936 JD A
David
01-08-2001 06:27:18
 Re: head repair in reply to Earl, 01-06-2001 17:03:49
Machine shop will need to press them out. They are available from Deere, but pricey - about $15 each if I recall.
Rhett
01-07-2001 07:59:53
the tubes are called push rod tubes,not shure where to find them
Will
01-06-2001 19:41:19
As far as I know the B is the only one with push rod tubes.
Larry E
01-06-2001 19:11:01
Why remove them if not leaking?
Earl
01-07-2001 07:46:14
 Re: Re: head repair in reply to Larry E, 01-06-2001 19:11:01
yes they are laeking
