'48 B Hard to Steer
DRL
10-14-2003 08:08:08
OK, I've done all I can think of, so now I'll see if some of the experts on this board might have an answer. Had steering troubles with this B before. Pedistal had been broken where the steering shaft goes into the top of the pedistal. Someone had done some "creative welding" to fix it. Thought this was the problem. I got another pedistal, upgrading from a "regular" front end to a roll-a-matic. Also purchased with the pedistal the original steering shaft so that the worm gear would be worn in the same places as the sector gear. Checked numbers on worm gear and sector gear, and they are a matched set. Both worm gear and sector gear showed very little signs of wear. Also, eccentric bushing was checked and it, too showed very little wear. Installed the pedistal and steering shaft. Went through all the steps outlined in the service manual. Checked for vertical movement. Checked for steering shaft end play and shimmed accordingly. Adjusted eccentric bushing according to the book. Greased the lower bushing at the grease zerk. Put a mixture of gun grease and gear oil in the upper gear box.
The tractor will drive out just fine if you are just parading it around, but when you are working it and need to make a hard turn either direction, such as making a square corner when mowing, or looping back on a windrow when raking hay, the steering will seem to hang in the turned position, and you have to manhandle it back to straight ahead. I have gone through and added shim gaskets to the front bearing housing, moved the eccentric bushing to every position that it has that does not bind the worm gear, and there seems to be no difference. Right now the steering is very sloppy due to my attempts to correct this problem, and you get a real good shakedown when going down the road. Also want to mention that the front wheels are set close together. I know that if they are turned around so that they are farther apart, this will cause it to be hard to steer. I have driven other tractors without power steering, and with the exception of my dad's Farmall M with a loader, have not had this kind of trouble.
If you have lasted through this long post, what, if anything can you all think of that might fix this problem.
Dave
10-15-2003 14:57:28
 Re: '48 B Hard to Steer in reply to DRL, 10-14-2003 08:08:08
Just a thought... Have you by chance overtightened the packing nut where the steering shaft comes into the gearbox? Maybe a combination of where the gears are not worn bad and the tight packing when you are making a short turn.
Jericho
10-15-2003 09:21:07
This is going WAY out on a limb, but could the problem be with your brakes? You mention that it happens after making a hard turn. Is it possible that you are braking on these turns, and the brake is sticking and making the tractor turn back hard? Like I said, WAY out on a limb, but something to think about.
Jon
10-14-2003 14:53:15
DRL,
I haven't had much experience with this problem but I noticed something on the model "D" that I am starting to re-assemble. With the tractor up on blocks and no weight on the front axle whatsoever, and with the drag link disconnected from the steering shaft, the steering components swing freely for about 20 degrees to the left and right of centre but suddenly get noticably stiffer past ~20 degrees - with zero weight on the axle! I suspect that 20+ year-old grease, dirt, and rust have bound up the pins and bushings. I would try jacking up your tractor and see if there is any noticable change in the tightness when turning the wheel from lock to lock. Then grease all of the joints with the weight still off the front end. If it steers easily under no load and becomes tight under heavy side loads caused by turning under high power, I wonder if something is dry and binding. You could disconnect each joint in succession to see if one of them really changes the "feel" of the steering gear. Does it bind up equally when turning both directions? Sorry for the long post - but a couple of things to try!
Jon
DRL
10-15-2003 04:26:04
 Re: Re: '48 B Hard to Steer in reply to Jon, 10-14-2003 14:53:15
Jon,
Tractor is a tricycle front end. Have had the front end jacked up off the ground several times. No noticable binding when there is no weight on it, but sure sticks when you want to get back straight on a tight turn.
