Bad Luck...
Howard H.
11-15-2003 17:02:48
Hi Ya'll,
Anybody have any recommendations freeing up an R that is "lightly" stuck??
I know the motor was free in May and the exhaust was covered then.
We had a tornado go through and flip the sprinkler over right next to the tractor (1/4 mile long center pivot).
I guess it sucked the can off the exhaust, but I didn't notice it until today. The motor seems stuck - I tugged on it with another tractor - but I didn't get very rough with it.
Should I just pour some oil down the stack?? Oil will just float - how can I displace the water that got in there??
We've had probably 4-5 inches of rain since May.
I know people are forever asking how to free a stuck motor - but I know this one wasn't stuck in May, so it can't have damaged the bore yet, if I can just get it free and hot and dried out...
Thanks for any advice!
Howard Henderson
Howard H.
11-19-2003 18:36:32
 Re: Bad Luck... in reply to Howard H., 11-15-2003 17:02:48
Hi Fellows,
Thanks for the hints...
I'm not going to drag it or anything, hopefully diesel/oil and warming the block will help - I'm going to try that...
It supposed to get cold this weekend, maybe as the block warms around the cold pistons, I can get it loose!
Thanks,
Howard
Clooney
11-16-2003 15:27:24
Howard, the questions is: is it really LIGHTLY stuck.. If enough water entered the exhaust stack or even dirt with that water you could be stuck tighter than you think.. If there is any water still in those cylinders you could easily bend a rod if you pull it or turn the flywheel without pulling the injectors or holding the valves open first..
~My suggestion would be to pull the cylinder head & take a look.. If there is mud or any debris in those cylinders you could easily do expensive damage to the engine by trying to free it.
~If you have ever priced any of those R diesel engine parts you might want to do all that's possible to not damage any.. On those high compression diesels it is easy to do engine damage when trying to free them.. In my estimation it isn't worth the risk versus the low cost of a head gasket set & few other low cost gaskets to look inside first...
~Maybe you'll get lucky & it will free right up, then again maybe it will cost you thousands if it doesn't & you bend or break something trying...
DON
11-16-2003 14:43:23
IF YOU THINK IT HAS WATER IN THE CYL.S THEN I WOULD REMOVE THE INJECTORS AND TRY TO TURN IT OVER . DON
F-I-T
11-15-2003 17:53:51
Howard:
You got a couple things on you side. It hasn't been stuck very long, and you have a decompression lever.
First I'd take off the valve cover and make sure the decomp lever is opening the exhaust valves like it should. Then I might even remove the injectors so I don't damage them or the tips. Seal the lines with some good tape. Then you could pour your penetrant down the exhaust manifold, or you could pour it into the intake (cleaner) and by screwing the intake tappets down, get it to flow into the cylinder. You'll need to just get the valves off their seats. Or you can funnel it into the injector holes if you choose to remove them. That should let you get it near half-full. I like to use diesel fuel to soak the cylinders, because it has some lubricating qualities, but it penetrates well and it's cheaper than most snake oils.
Now the next step is a leap of faith, but it has worked for me in the past. Put a garden hose valve in the drain plug hole of the head, and after turning your water heater to high, fill the system with hot water from the bottom up. After it gets full, close the valve until it just trickles out so it stays pretty hot (say 140*, about the best a home water heater can get it) and then try to rock it back and forth and I'll bet it will come loose after that warmn diesel fuel gets to flowing.
Oh, by the way. At 415.5 cu.in displacement, and one cyinder up and the other down, or both half-way, that leaves 1 full cylinder to fill, or 207.75 cu.in, which is 3.4 litres, or about 9/10 of a gallon of diesel fuel you'll need. You ought to be able to steal that much out of the tank.
Other than that, good luck!
Frank-in-Tallahassee
70D // 855 // VAC
[email protected]
n.f. owen
11-16-2003 17:22:49
 Re: Re: Bad Luck... in reply to F-I-T, 11-15-2003 17:53:51
hh, chrysler used brake fluid to free tight parts, like heat risers. you can use it to fill cyls. it may swell rubber seals, so maybe have the oil drained & plug out of drain. be blessed, it is hygroscopic, absorbs water, also
