wide front weight?
Andrew
11-15-2003 16:53:41
What is the weight of a wide front off a John Deere G?
Dennis
11-16-2003 05:18:28
 Re: wide front weight? in reply to Andrew, 11-15-2003 16:53:41
Andrew,
There is not a lot of difference between the round WF on a BW and that on a GW, and my owner's manual has the weight of a BN at 4040 and the BW at 4320, a difference of 280 pounds. Now I'm guessing the 16-inch single front on a BN can't weigh more than 120 pounds which would make the weight of the wide front about 400 pounds.
Dennis
The Dukester
11-15-2003 19:34:48
My '48 GW weighs 6100.
MIKE HANLEY
11-15-2003 18:33:25
A square axel for a 20 30 series tractor will add 750# more that what the tractor would weight with a roll-a-matic to the front end. A G with most of the front end cast, (as opposed to an after maket front end that is made of welded stock steel) it will be pretty close to that
