John Deere R's
Chuck McDonald
01-04-2001 20:08:45
Hi,
I have been seeing pics of JD r's and i was wondering if anyone out there could share their experiences with them as i have not been around them much. Alos i ahev heard that parts for this pony engine are hard to come by. is there much truth to that. Anyway, anything will be greatly appreciated,
chaz
aka "Tractor Boy"
Dick B (IL)
01-06-2001 07:33:14
 Re: John Deere R's in reply to Chuck McDonald, 01-04-2001 20:08:45
As a youngster I grew up on a small farm in central Illinois. A neighbor had an R that was his big tractor at the time. It had been converted to dual exhaust. I often remember hearing that R working on a still night in the Sangamon River bottom country he farmed. Under load you could hear it working from a long way off.
G Taylor
01-05-2001 23:23:47
While lots of people like R's the later versions as 80,820,830 etc are even better as they were refined & debugged. The crank was updated with three main bearings, a more powerful pup engine, power steering, a stronger pto, more hydraulic options, another forward gear, engine water pump, variable injection timing, more power & etc.
Chuck McDonald THANKS!!!!
01-05-2001 22:49:34
hey,
thanks to everyone out there for the advice about R's. Sounds like evryone likes em. NOTHING LIKE THE SOUND OF A BIG STROKE, 2-CYL DIESEL TO SEND ANY OTHER TRACTOR RUNNING FOR THE SHED!!!!! One more ?..... .Where can you buy pony parts for em? Also anything thats hard to get or was weak on em (other than the PTO!!)? Once again, thanks,
chaz
aka: "Tractor Boy"
HiK
01-05-2001 19:20:25
Restored an R two summers ago, and parts aren't as hard to get as you'd think. If the pony's good and at least running, you shouldn't have any trouble. All of the gaskets are available in a big ole gasket set, and if properly taken care of, the pony should (and will) outlast the big motor. Unfortunantly, too many people took advantage of the little guys, didn't care for them, and that's why there's a good parts market for them! I love the R for a big grunting tractor, and used it to pull back the sled at a tractor pull last summer. Hooked her on the sled after the pull, and he couldn't stop me! Neither could a 20 ft White disk my neighbor left lying around, but that's another story!!!
ron
01-05-2001 14:33:39
Ran an R summers of '52 and '53 for an uncle. It was new in '52 and would go on one filling of the fuel tank per day running 10 hour days. Pulling a 16 ft Graham Hoeme chisel for summerfallow or a 4-16 moldboard plow for fall plowing. This was in small grain country. 14-34 rear tires with water in them and 3 sets of wheel weights on each side. A real lugger and easy to drive.
Gpower
01-05-2001 07:18:59
I have a 1950 R that I pull with. She is all stock and I dont have weights on it. I have totally restored her, and I didnt want to start hanging weights on it. The good thing about the R is that is has an 8 inch stroke. This gives it great low rpm torque. My tractor will put out about 1250 RPM's. We pull here in TX and I there are a few R's that pull. As to a 730 betting them all the time...not here they dont. Maybe a few times. The r's that are weighted down and up to about 10,000 pounds or more go out the end of the track every time. I have been beat by a 620 gas, but he had water in the tires and a modified engine. I dont have water in my tires, so my bigest problem is spinning out. I have only run out of power a few times and that was when I pulled in second gear. I am not doing this to beat everybody I am just out there having fun. If i wanted to get serious I would have weights all over this baby, but I am not into that. Anyhow they look good and they put on a good show..and they are lots of fun...
jdrpuller
01-05-2001 19:54:06
 Re: Re: John Deere R's in reply to Gpower, 01-05-2001 07:18:59
My father and I also pull JD R's. They are both 1953 models. Dad's is strictly stock,as he still uses it for work around the farm. We have done some work on mine and parts were not much trouble to get. She is a good strong puller here in Nebraska. We do this for the fun of the sport and were lucky enough to take 1999 Div 2 7500 Championship and the 2000 Res Championship in Div 2 7500 and 8500.
I just love to hear these big brutes under a load,it is one the most amazing sound.
Rick
01-06-2001 07:31:40
 Re: Re: Re: John Deere R's in reply to jdrpuller, 01-05-2001 19:54:06
where those John Deere R's and 80's good at saw mill work I was thinking of getting one to run the saw mill I have.
Gord
01-06-2001 08:26:17
 Re: Re: Re: Re: John Deere R's in reply to Rick , 01-06-2001 07:31:40
I would say as long as you are using the belt pulley to drive the mandrel you would be OK. The unfortunate weak link on the R is the 90 degree gear drive for the PTO in the belly of the transmission. It really is undersized for the amount of power that the diesel can put to the shaft and when you lose the gears you lose the trans lube pump also. Gord
Duben
01-04-2001 20:39:27
Spent lots of hours on an R in the early 60s. They would work all day on 15 - 20 gallons of diesel. Good for plowing or heavy field work. Now I have a 730 diesel w/ pony start. It easily outpulls R's at the tractor pulls I've been at and is more useful with the row crop design and the three point hitch. Really depends on what you want to use it for. Have to be careful with the ponys - warm them up good and keep in tune. Haven't had much need for parts, but I understand the dealers don't have much for the ponys. Don't think you would have that much trouble finding parts if you look in the Green Magazine ads. I know a pony beats a direct start in cold weather. Love the sound of that pony cranking up the diesel!
