Clutch Replacement for Farmall H
john
01-04-2001 14:07:51
I believe my 41 H needs a new clutch. Anyone out there ever put one in? I have plenty of tools and jacks. What all is involved in doing this? Thanks.
Jarrod
01-05-2001 17:31:55
 Re: Clutch Replacement for Farmall H in reply to john, 01-04-2001 14:07:51
I don't believe that you need to split the tractor. You should be able to get to it by taking off the bottom cover and possibly the belly pump. I think you can reach up in there and disconnect the driveshaft on the back end. Then take it out. Then reach up in there and disconnect the pressure plate and there you are. However I don't know if you can get the flywheel out this way if it needs surfaced. It should come out but I've never done it.
ridge runner
01-04-2001 17:26:28
Tractor must be split. Need device to roll one part of tractor forward or back. Can be done a few wrenches and 1/2 drive socket set. The H has a bolt hidden inside the starter housing that must be removed before the split will happen.
BTD
01-04-2001 17:03:16
I think you can do it without splitting the tractor. Guys in the Farmall board would be happy to help. Good thing you have a sweet purring Farmall and not one of those two cylinder noise makers. BTD
JDFREAK
01-05-2001 19:56:29
 Re: Re: Clutch Replacement for Farmall H in reply to BTD, 01-04-2001 17:03:16
And you probably think Japaneese bikes sound better than Harley's too.
JDF
BTD
01-06-2001 19:30:22
 Re: Re: Re: Clutch Replacement for Farmall H in reply to JDFREAK, 01-05-2001 19:56:29
Would those Japanese bikes be Yanmars like the new John Deeres?
luckydog
01-04-2001 16:39:56
Drop 2 pistons and slide it out the side
Karl
01-04-2001 15:06:58
Uh... try the Farmall board, here at the JD board you might not get many answers...
Hope this helps!
Karl
