Camshaft timing on JD G
FB
01-01-2001 20:43:40
I am putting the camshaft back in my 49G. I installed the camshaft in the tractor so that the V-mark on the cam gear lines up with the dot on the crankshaft gear.
After this when I make a full rotation with the crankshaft the dot on the crank gear does not line up with the cam gear. After I make another rotation with the crankshaft the two gears index on the dots. I realize that I am rotating throught the different cycles. My question is.. is it possible to get the camshaft gear and the crankshaft gear out of time even if I have the two indicators indexed properly.
I think I have it correctly but I just want to make sure.
49g
01-02-2001 01:27:31
 Re: camshaft timing on JD G in reply to FB, 01-01-2001 20:43:40
It sounds like you have them right. If they line up on one rotation they should be 180 degrees off on the next. Give or take a little. Best of luck, Scott
JDGnut
01-03-2001 12:27:54
 Re: Re: camshaft timing on JD G in reply to 49g, 01-02-2001 01:27:31
Like 49g said.. I think U have it right.. Just remember that the cam turns 1/2 the speed of the Crank.. So it takes 2 turns of the Crank to equal 1 of the Cam.. JDGnut
