John Deere A ?? Year Model ??
Richard
01-01-2001 18:39:27
I need help in determining the year model of an A I recently purchased. Cannot check by the serial number since it is missing. The tractor has a slant dashboard, round rear axle, metal pan seat, and the battery is located behind the dash. Can anyone determine the year this tractor was manufactured from these specific items?
Mike in Mo
01-01-2001 19:48:51
 Re: John Deere A ?? Year Model ?? in reply to Richard, 01-01-2001 18:39:27
Can you give some more info?. I can narrow it down to a 1939-1946. Does it have a 4 speed or 6 speed trans, angle iron or cast frame, 1 piece or 3 piece hitch frame? I'll try to narrow it down more if I can. Mike
Richard
01-03-2001 17:38:09
 Re: Re: John Deere A ?? Year Model ?? in reply to Mike in Mo, 01-01-2001 19:48:51
Thanks Mike, the tractor has a 6 speed transmission and a cast frame. I'm not sure what you are asking in regard to the 1 piece or 3 piece hitch frame. It has a swinging draw bar. Is there anything else specific to a certain year that I can look for?
Mike in Mo
01-03-2001 20:56:41
 Re: Re: Re: John Deere A ?? Year Model ?? in reply to Richard, 01-03-2001 17:38:09
Richard- the cast frame was used in 1943 and 44 only due to wartime material shortages. The very last "early" styled A's had the hitch frame welded together instead of being bolted together. Hope this helps out. Mike
