48 A WITH A FACTORY TACH???
MSKOCH
11-15-2003 08:57:37
I RECENTLY BOUGHT A 48 A WITH A TACH MOUNTED ON THE LEFT SIDE OF THE GOVERNOR BOX. I HAVE NEVER SEEN ONE ON AN "A" BEFORE. IS THIS FACTORY AND IF SO, HOW MANY WERE MADE LIKE THIS? THANKS IN ADVANCE!!
jdman(MO)
11-15-2003 12:44:14
 Re: 48 A WITH A FACTORY TACH??? in reply to MSKOCH, 11-15-2003 08:57:37
Well the B parts books shows a hour meter,I have never seen one, says it is 6 volts. Probably not a tach though. Russ
F-I-T
11-15-2003 17:20:17
 Re: Re: 48 A WITH A FACTORY TACH??? in reply to jdman(MO), 11-15-2003 12:44:14
Not sure which "B" parts book you have, but if you have a PC0330, it shows the Speed-hour meter that was driven off of the left end of the governor (provided you installed the special governor shaft) on page 26. Aparently it was only available for S/N's 201,000 and up. I can't find it any of the other "B" books.
Frank
jdman(MO)
11-15-2003 19:58:27
 Re: Re: Re: 48 A WITH A FACTORY TACH??? in reply to F-I-T, 11-15-2003 17:20:17
Interesting, I did not see that one. I was looking at the one on page 63 which the book shows effective 60000 using a pressure oil switch. Russ
F-I-T
11-16-2003 07:46:24
 Re: Re: Re: Re: 48 A WITH A FACTORY TACH??? in reply to jdman(MO), 11-15-2003 19:58:27
Yes, that's the hour-meter that is electrically driven. It was a neat idea to use the oil pressure switch to complete the circuit.
joe
11-15-2003 10:50:39
Someone before you probably changed the gov. housing from a 60 and put it on your A, or perhaps just the internal workings along with the side cover.
