Help replacing 1010 sleeve
Dan Settles
12-29-2000 19:06:50
We're rebuilding the engine of my JD 1010 tractor. The sleeve unit is in pretty good shape, so we are putting it back in the engine after it gets cleaned up. We have all the parts ready to go, but I'm a bit nervous about doing this after reading the old posts about this. It sounds like getting the sleeves back in without having coolant leak into the oil is a tricky job. I would really appreciate some advice about how do do this right the first time.
Gpower
12-29-2000 20:15:40
 Re: Help replacing 1010 sleeve in reply to Dan Settles, 12-29-2000 19:06:50
Well, we always get liner soap from the John Deere dealer. Get your o-rings in the block, take some of the liner soap and lube up the o-rings. Slide the liners down in the block..careful not to drop them or force them in...you should be able to push the liners in by hand all the way down..maybe have a 1/2 left out. Usually they will slide right in. Just make sure you have the o-rings in good, and dont let the lip of the liner catch the edge of the o-ring. Make sure they are in the block grooves correctly..and you should not have any trouble...the o-ring soap will help. Good luck...its really not as bad as it sounds..done plenty of them..
Gpower
12-29-2000 21:59:41
 Re: Re: Help replacing 1010 sleeve in reply to Gpower, 12-29-2000 20:15:40
One other thing I forgot to mention...and is important..liner height.. this will enshure the proper "crush" of the liner to the block. You can put the liners in without the o-rings first..to make sure they fit in properly and without force. You can measure the liner height with a dial indicator. It is usually between 1 to 4 thousanths of an inch in height..depending on the manual specs. The liner protruding up from the block at the 1-4 thousanths of an inch will give the proper "crush" of the liner when you install the head and torque the head down. This will need to be done within specs to keep from having head gasket problems and leaking. Hope this helps...Gpower
ROBERT
12-31-2000 20:51:04
 Re: Re: Re: Help replacing 1010 sleeve in reply to Gpower, 12-29-2000 21:59:41
not on a 1010 or 2010 the lines are welded to a plate and all for one and one for all at wontch.
ROBERT
Larry E
12-29-2000 20:21:05
Dumb question ,what is o ring soap?I have used jelly type silicone
Gpower
12-29-2000 20:59:25
 Re: Re: Re: Help replacing 1010 sleeve in reply to Larry E, 12-29-2000 20:21:05
O-ring soap..or piston liner soap..it comes in a quart container..kinda looks like dishsoap..but it better than dish soap..more slimy you might say..and it is soapy..
ROBERT
12-29-2000 20:39:22
the book say liner sope or mild dish soap
but neve use an oil base lube it will swell up
and cose the line and piston to seze up.
ROBERT
