Regulator
Betty
12-28-2000 07:58:18
I have a 51 or 52 John Deere B. Serial # is 275922 I have the specifics to set opening voltage and closing voltage, etc. The current and voltage appear to be 1 relay, however it has two sets of points. (Cutout is a separate coil) I need a procedure to set the regulator, and an explanation of how it works. Thanks.
clooney
12-28-2000 12:19:04
 Re: Regulator in reply to Betty, 12-28-2000 07:58:18
Betty, the (proper) settings on a regulator require an accurate volt meter & a complete understanding of the type of regulator you have & usually the insertion of a fixed resistance in the battery wire. It usually involves a variable resistor in the field wire also. Without these things there is no good way to determine at what voltage the points are opening & closing or if they are operating when they are supposed to. If you have the proper specifications the air gaps can be set & the point opening on the cut out can be set but once you mess with them then you have to do a complete regulator adjustment. If the regulator is misadjust you could fry a good battery. It would take me a full day to type out the complete adjustment procedure & even then your regulator could be different from the procedure I send. Some regulators are adjusted by bending spring tabs others by adjusting tension screws, still others by actually moving the armature (arm) up & down. To try to answer your question on the current & voltage using a common relay.... On the current-voltage type of regulator there is usually a current sensitive & voltage sensitive winding wound on the same core with the load being placed on the current winding (usually "L" terminal) the battery charging remains on the cut-out relay & is voltage sensitive to prevent battery overcharge. Sorry I didn't answer your question completly but you will probably need a manual to fully understand the adjustment procedure & then if it doesn't cover your exact regulator it won't help that much. In the long run it will be much cheaper to buy a new regulator.
