Help ID carb
RobertN
12-27-2000 09:39:59
I rebuilt the carb on my '41 Farmall A, only to find it really does not fit properly. It had small bolts installed so there was enough slop for it to mount up to the intake. The choke shaft and throttle shaft that came in the Tisco rebuild kit did not fit right(I ordered based on year/model of the tractor). The floats were the same...
The carb is a Zenith. On the bottom is a stamp "B2". On the top is a tag "10850A". I measured the carb; the holes are 2-1/4" on center. Next I measured the intake; the holes are 2-3/8" on center.
Any idea's what this carb is really for?
Karl Bader
12-27-2000 13:34:05
 Re: Help ID carb in reply to RobertN, 12-27-2000 09:39:59
Try posting this on the farmall board.. the green guys here might not know much about farmalls...
Hope this helps!
Karl
RobertN
12-27-2000 13:42:16
 Re: Re: Help ID carb in reply to Karl Bader, 12-27-2000 13:34:05
Thanks Karl, I have done that.
The best advice I could get is to ask all the boards, since Zeniths appear to have been used on numerous tractor brands.
Best lead so far is it may be from a Allis...
Karl Bader
12-27-2000 13:44:38
 Re: Re: Re: Help ID carb in reply to RobertN, 12-27-2000 13:42:16
Good luck!
Karl
RobertN
12-27-2000 14:49:10
 Re: Re: Re: Re: Help ID carb in reply to Karl Bader, 12-27-2000 13:44:38
Thanks! I think I need it ;-)
