JOHN 1010 GAS
ALFRED
12-24-2000 17:42:02
WHERE CAN I FIND A ENGINE SLEEVE KIT?
Sam
12-25-2000 06:48:37
 Re: JOHN 1010 GAS in reply to ALFRED, 12-24-2000 17:42:02
Best inexpensive fix is a JD40 combine engine. Exact same engine (JD115 power unit) You will have to change some externals -oil pan, dip stick, valve cover, carb, etc. I purchased a running engine in Indiana for $250 a couple of years ago. If you rebuild be sure to have your block checked as most are cracked between the cylinders. Good luck on your 1010 - you will need it.
ret
12-24-2000 18:52:47
get one from your JD dealer. $425. deere recommends new pistons when replacing deck. About $80 apiece. Whatever you do, have it CLEAN around the bottom of the block where the sleeve fits into
